Results 1 to 3 of 3
Thread: 380 2007 - Relay locations
    Aug 2018
    Default 380 2007 - Relay locations
    Hi. Want to make sure the relay isn’t causing my blower problems. Is there a location map for the various relays I can use to test. I believe it’s located in the drivers fuse panel area. Cheers. Nicholas.
    Home grelise's Avatar
    Feb 2008
    The one on the drivers side behind the fuse panel cover is your ETACS. I have a copy of the workshop manual and I'll check tonight if you like. Unless someone else finds it for you first. I have a spare ETACS unit here and spare relays.
    AMC///WA
    My Ride
    Aug 2018
    Cheers. Good to know. Is it an actual fuse or one of the square black units next to the fuses. Trying to exclude it before I start ripping the dash apart to replace the blower transistor. That thing is buried deep!
