Hi all,
No luck with the search in relation to this issue. My 380's cigarette lighter outlet has stopped working. Fuse is fine so I was going to take it out and see if any issues with the actual unit. Not sure how you get this out. Do you remove the entire trim piece around it or does it pop out on it own? I just hoping it is not a more difficult to fix wiring issue.
Any help would be much appreciated.
It has been intermittent for a while but went after I installed a reverse camera/dash cam that was powered from it. I have now wired this to the 12v courtesy light feed instead (with a 12v to 5v converter). This is actually quite useful as the body control module turns the power off to the courtesy light wiring after a few minutes thus you get a some recording after parking. Still need the ciggy light for phone charging etc.............
Steve
