Originally Posted by
Ensoniq5
My point is that, on the 3rd Gen TB, the TPS cannot be adjusted without moving the point at with the idle switch triggers, since they are integrated into a single unit. For this reason the TPS setting procedure concentrates on the point at which the idle switch triggers rather than min/max resistance across the TPS range, which is only tested to verify that the sensor is working properly. The older 1st/2nd Gen setup was different, the idle switch was on the end of the concertina-shaped idle speed controller and the throttle position sensor was a separate unit.
My concern is that someone reading this thread may assume that tweaking the position of the TPS is a valid way of correcting some gear change behaviour in 3rd Gens, this may well be valid in earlier Magnas or other vehicles where the TPS is separate from the idle switch but is likely to introduce idling problems with the 3rd Gen throttle body setup, as far as I understand it. In most cases the TPS will never need to be adjusted from factory settings, so you're spot on regarding the white paint dot which will be unbroken in most cases.
