Car: 2001 Advance TJ
Engine/driveline: 3.5lt Manual (converted)
Mods: Sprintex Supercharged @6.5psi, extractors, high flow cat, exhaust, high flow muffler, factory ECU flashed, Walbro fuel pump, high flowed injectors, engine stock.
Dyno: Dyno dynamics @ Hitman Tuning
Power: 164.8 kwatw
Really MAX kw does not tell the whole story as timing was retarded a LOT at high revs to protect the engine (due to the lack of an inter cooler), on a "happy run" as Matt (Hitman) called it, car pulled out 175kw max power, as with any forced induction torque at early revs is absolutely insane, you can hear tyres loosing traction in 3rd gear when puting the foot down on a highway!
N/A
