Results 1 to 2 of 2
Thread: Throttle Position Sensor TW
    Nov 2005
    International Member
    Default Throttle Position Sensor TW
    Hi I own a 2005 TW VRX sedan I want to check the position of the TPS Mine has THREE terminal wires
    So can anyone tell me which terminals I should connect an Ohm meter across to find the correct position when rotating the TPS from showing a reading to open circuit.
    It also has Traction Control fitted.
    thank you,
    George.
    May 2018
    Have a read of the thread in the <Third Generation Magna TE - TW> section called "unstable idlling-stalling im going nuts".
    Around page 6-7 someone was talking about TPS checks similar to what you are asking.
