Results 1 to 8 of 8
Thread: TF ECU Location
    Jul 2012
    Default TF ECU Location
    No sign of the ECU directly under the radio where both the manuals I have say it should be so where is it?
    It is on the tunnel under the centre console pretty much against the fire wall (under the heat box)
    AMC Awards finalist lowrider's Avatar
    Mar 2006
    I found easy access from the passenger footwell. well thats where i wired in a piggy back ECU into from.
    Quote Originally Posted by Richard Hammond
    "I am a driving GOD!!!"
    my ride, check it here: https://www.aussiemagna.com/forums/sh...ight=lowriders
    AMC///two tone division
    AMC///Black and 20 inches divison
    AMC///magna awards finalist 2009
    Jul 2012
    Thanks for your quick replies Mal and Lowrider. I assume the heat box is the large plastic structure behind the radio. Still can't see anything. I'll try and get a photo of what I see when it's not raining. Is it under a plastic cover or anything like that? I'm looking for a silver module.
    Does the position differ on different models?
    What did you remove to get access from the passenger footwell lowrider?
    Mark it zero. ammerty's Avatar
    Dec 2011
    Quote Originally Posted by Riverman View Post
    The position is the same on all 3rd gens.
    Pull back the passenger side carpet from the frontmost inner section of the footwell where one's right foot would go, which will reveal a metal plate located on the lower RHS of the footwell, on the side of the tunnel, under the console trim. Unscrew it, behind it you will find the ECU staring at you, possibly sheathed in a plastic sheet.
    Jul 2012
    Thanks very much for that advice ammerty. I'll try that procedure in the morning. Looking forward to finding this thing.
    Jan 2019
    Did Riverman ever find his ECU??
    Sep 2013
    Quote Originally Posted by bundits View Post
    Now i wonder if he still has the car ?
