Results 1 to 5 of 5
Thread: Transmission/diff oil for Verada KJ
    Mar 2015
    Default Transmission/diff oil for Verada KJ
    I have Penrite ATF FS fluid which I am thinking to use in my Verada. Is it safe to use non-Mitsubishi oil in the transmission?
    The price of Mitsubishi ATF is $115 which is very expensive than other brands of oil.
    I may also change the diff oil of any brand, how much do I needed.
    Thanks
    Dec 2008
    I fail to see why a dealer is charging you so much for genuine SP3 Mitsubishi Trans fluid. I bought a 5 litre bottle from the local dealer for $48 & it was about a dollar cheaper the time before.
    Tell your dealer that there's a mistake, you shouldn't be paying more than 50 or so dollars.
    5 litres is enough for a regular flush & you'd need just under 9 litres for a full flush.
    Personally, I only ever use genuine Mitsubishi diamond SP3. When I went to the transmission specialist to get my transmission seviced & wave spring washer replaced a few years ago, I had a blonde moment & bought 9 litres of Nulon fully synthetic multi-vehicle transmission fluid. The transmission guy just looked at me and then strongly recommended I use the genuine fluid as there would be a chance of erratic transmission behaviour or premature failure if I used something else. I promptly returned the nulon & repaced it with genuine. My mechanic is of the same opinion concerning Mitsubishi automatics - only use genuine.
    The diffs aren't so anal as the auto trans, so I used nulon diff fluid for the transfer case & nulon LSD fluid for the rear diff. Again you can get genuine Diaqueen diff fluid for the the AWD's diffs & buy the diaqueen friction modifer to add to the fluid for the rear LSD.
    Diffs require very little fluid, only around 250 mls for the transfer case & about the same for the rear LSD from memory.
    Nov 2014
    Same info as ADM, only use Mitsubishi oil in transmission. For the transfer case and diff I used Penrite 80w - 90 with the anti shudder modifier. I bought 2.5l of the gear oil and I have approx half a bottle left so transfer case and diff do not take much oil at all.
    Mar 2015
    Guys
    Thanks for the information. I will buy only Mitsubishi ATF. I also contacted other dealer and he selling much cheaper than other.
    Just wondering if is it easy DIY...
    Jun 2010
    I have used Fuchs recommended trannie fluid since the warranty ran out MANY moons ago...I thought the trannie had started to playup a month ago but it was a sensor sending erratic info...stunned transmission man with mileage ...315000...never been touched 'cept for fluid changes around due date....Fuchs oil in engine and diffs too ....not a murmur out'v them....(hope I now have not jinxed meself .....)
