Page 7 of 7 FirstFirst ... 5 6 7
Results 61 to 67 of 67
Thread: ECU definitions for ECUFlash
  1. #61
    Jun 2013
    Quote Originally Posted by WytWun View Post
    Oops - the link to the downloadable definition package in the first post was actually to the old set of definitions
    Now fixed...
    I should add if you are using my ROM to add to the definitions database then by all means do so.
  2. #62
    Needs MOAR BOOST!!! UNARMD's Avatar
    Nov 2013
    Hey WytWun... would there be any chance of you looking at a leggy rom and seeing if you could add a transmission definition to it? would be great to be able to adjust some trans values
    Mawson White KL Verada AWD "Magna Evolution"
    Black FL Galant VR4
    Ironbark 30th Anniversary Outlander
    State Rep VIC
    AMC//////ALL WHEEL DRIVE DIVISION
  3. #63
    WytWun's Avatar
    Aug 2009
    Australia's Capital Territory
    Quote Originally Posted by UNARMD View Post
    Do you know what sort of ECU (H8 or SH2) is in the car? I've been under the impression that the Legnum ECUs were all H8, even in post 2000 cars. H8 auto ECUs actually have 2 separate ROMs: the first is for the engine and the second for the trans. Each ROM is 128kB in size. The standard reflashing cable only works with the engine ROM; getting at the trans ROM requires a wiring mod to the reflash connector wiring to swap the reflash signal between the two wired pins when desired. There is a reasonable chance of finding the speed based shift maps in an H8 trans ROM if you can read it.
    If the ECU is an SH2, the auto ROM will be 512kB and that I can easily deal with. You may need the custom read template mentioned in the first post to read the whole ROM in that case.
  4. #64
    WytWun's Avatar
    Aug 2009
    The wiring mod to the reflash connector wiring mentioned in the previous post may also permit access to the trans ROM in H and late F series Magna/Verada ECUs, provided that there are two wires running to the reflash connector.
    Auto cars with SH2 ECUs only have one wired pin in the reflash connector as the trans code is in the same ROM as the engine code.
  5. #65
    BCX7's Avatar
    Apr 2004
    Already have some auto stuff defined, can define more if required.
    https://www.ozvr4.com/threads/officia...-thread.11840/
    RIP - Fully Jet Black '85 Magna
    2000 Galant VR-4 Type V
  6. #66
    Jan 2005
    Anyone have a manual ralliart tune adjusted for 98 Ron available?
  7. #67
    WytWun's Avatar
    Aug 2009
    Updated set of definitions available via first post.
