Results 1 to 3 of 3
Thread: 2002 Verada X1 Air Conditioner
    Nov 2011
    Default 2002 Verada X1 Air Conditioner
    Air conditioner losing gas. Tried 'Leak Guard' sealant. Eventually found leak in hose that runs behind the radiator. I think it is called the discharge hose. Local Mitsubishi dealer is quoting $120.00 for the hose, plus fitting. Is this reasonable? Other alternative is hose from wreckers at $50.00. Should I take the Mitsubishi dealer's offer?
    Quote Originally Posted by kleo View Post
    System needs to be evacuated, hose replaced, regassed. I'd be more interested in the all up cost, $120 for the hose is just the start.
    Whatever you do, don't buy a hose from the wreckers. Any filth inside it has the potential to destroy most parts of the system.
    Perhaps take it to a shop that specialises in car air con units, might be cheaper.
    Mar 2013
    You might be able to get it repaired at a reasonable cost too at a dedicated air cond service centre.
    Obviously you have to weigh up the cost of them repairing it/fabricating a new one vs genuine. Usually air cond service centres can make pipes and hoses provided your one doesn't have very complex metal bends.
    Recharge costs vary between about $60 and $160 I have found recently. Get the place refilling the system to quote on repairing or making the rooted pipe and balance that against the cost of the genuine pipe.
    I wouldn't recommend a secondhand rubber pipe on the high pressure side. A secondhand metal only pipe (as opposed to a metal and rubber) might be OK if it hasn't suffered similarly to yours. No secondhand rubber!
    Assuming one hour to replace the pipe/hose, $120 re-gas and $120 for a genuine pipe then to fix it might be under $350 (if you're lucky).
