Results 1 to 3 of 3
Thread: TJ VRX upper oil sump removal - I'm stuck !!!
    Jul 2018
    Default TJ VRX upper oil sump removal - I'm stuck !!!
    Help im stuck.
    I am trying to remove upper oil pan but seem to have a problem. I have removed all the bolts holding up the upper oil pan from the engine block , ive pryed it apart from block, it comes down evenly about 2 inches but for some reason will not remove or separate completely, like something is holding it on at the rear end of the pan at transmission ( Auto) .
    I would post marked up images but am not allowed.
    As per haynes manual recommendation, Ive removed:
    • dipstick tube
    • Starter
    • cross over exhaust underneath
    • lower oil sump
    • all upper sump to engine block bolts
    I have not removed:
    • transmission cross member
    • transmission mounts on cross member ( are these as haynes describes "engine to transmission support brackets"
    • transaxle inspection cover ( not sure where this is - can somebody enlighten me?? )
    Im thinking maybe the girdle is interfering with it ( upper pan) coming off, because when I lower the pan down to remove it, it comes down 2 inches and hits the crossmember, but I would have thought 2 inches down was enough to remove it but maybe not - just did not want to remove transmission mounts??
    Do I have to remove the transmission mounts on the crossmember to lift the engine for more clearance?
    stuffed if I know....really doing my head in.
    Any help appreciated.
    Wombatkarl's Avatar
    Oct 2009
    Oil pickup will stop it
    Jul 2018
    Done - bit the bullet and undid the Tranny crossmember - the extra clearance underneath did it
