Originally Posted by Halogen
IMO Don't spend all that money until you test the idle circuit.
At idle, the yellow/red wire is earthed by the TPS when properly adjusted.
It's switching a large voltage and eventually becomes ineffective.
Temporarily earth the yellow/red wire to the black and see if it improves after 5 Mins (don't rev engine at this time) An easy way to do this is use 2 pins to pierce the insulation on each wire and then join them, making sure they don't touch chassis. Use only these 2 wires ! If not experienced, get someone who is.
If still unsatisfactory, look to improving ignition/combustion
Cheers Barry![]()
