Results 1 to 6 of 6
Thread: Reset "base idle"?
    KWAWD's Avatar
    May 2012
    Default Reset "base idle"?
    What is the consensus here about "reset of base idle" after battery disconnection?
    I've read mixed views, with some saying it must be done (hooking up to a scanner and adjusting it) and some saying no need and the ECU will figure it out automagically.
    What's the real position?
    Administrator Madmagna's Avatar
    Jan 2003
    If you base idle was correct prior there is no need to redo after reconnect. All depends on where your base idle was set prior to the disconnect
    Mits-fix E-Bay Store here
    Mits-Fix on Facebook here
    Mark it zero. ammerty's Avatar
    Dec 2011
    Its not needed. The ECU should sort the base idle out by itself if it was fine before.
    KWAWD's Avatar
    May 2012
    Excellent. thanks!
    Nov 2005
    Just be wary of the idle after you have disconnected the battery for a while.
    Both my third gens refuse to idle after a disconnect. Takes quite a while for the ECU to bring it back up. Not fun stalling the engine at a traffic light, or entering a corner with throttle off. I need to keep the revs up with the throttle, allow the revs to drop down to almost a stall, then bring them back up with my foot. Repeat until it's steady. I normally do this stationary. Bit of a pain if you try to rush the process and drive off early.
    Jul 2013
    Does base idle reset need to be done with special equipment or can most mechanics do it?
