Results 1 to 8 of 8
Thread: help to remove crankshaft pulley(tr 2.6L)
    Nov 2013
    Default help to remove crankshaft pulley(tr 2.6L)
    in order to replace the crankshaft oil seal,
    when loose the belt for alt and air conditioner,
    loose the bolt,
    but found the pulley is stuck to the crankshaft,
    making it hard to remove.
    Any idea?
    thanks
    Jan 2012
    If the TR is the same as the TP and before you have to remove driver side gearbox mount and tilt the motor to have room for the pulley to slide off the crankshaft or else it hits the front chassis rail.
    If it is still stuck on the shaft (probably some corrosion)once in the lowered position as above you should be able to get a pulley removal tool on it once you take the bolt out. Also spray some penetrating fluid on it like inox. Vee
    Nov 2005
    As above, it is a sliding fit unless corroded on.
    Seen a few that were difficult to remove, and in each case the splash guard was missing or damaged.
    If your crank pulley has a rubber band insert (can't remember if these do or don't) , don't use a puller that grabs the pulley at the outside circumference, you will destroy the pulley. Lots of penetrating fluid and let soak. If the pulley has bolt holes, you could improvise a slide hammer, perhaps?
    Nov 2013
    thanks!
    could you please tell me the complet brand and product name for the penetrating fluid?
    Sorry! the first time to do the job.
    since oil leak severe in the time chain case side( for many year, juse gradually worse now ).
    Is it possible the plastic seal soft or melt and stick the pulley with the crankshaft?
    Nov 2005
    WD40.
    Not likely that the seal is glueing up things, rust is more likely.
    Nov 2013
    appreciate that!
    front side is bolt, rear side is seal,
    should spray the fluid to both side?
    Jan 2012
    Front is all you can do really as the rear part of the pulley goes thru the seal so you cannot get to that. Its is a tight fit on the shaft so some wriggling will be needed usually. Vee
    Nov 2005
    Spray the joint between the pulley and crankshaft from the front.
    Wriggling is good. See if you can detect some movement by pulling on different parts of the pulley, spray and wriggle, spray and wriggle, etc.
