I know this probably has been said many times but what do we have to change when you wanna lower ya magna as low as she can go. do I need to get camber and castor kits. I know I need new spring and shocks to suit, but what else.
Thanx
Thanx
To lowere you car u can just swap the springs. If you go lower than 2 inches you'll need a camber kit.
If you want to do it properly replace your springs and shocks at the same time. Simple.
get koni adjustable coil overs![]()
i got quoted approx 2g +
then plus labour etc.!
Part# Description Price Quantity Total
75301 WL h/duty coil spring - pair - $145.45 1 $145.45
70086 WL h/duty coil spring - pair - $145.45 1 $145.45
K86401306 Koni Shock Absorber - $205.65 2 $411.30
K80401107 Koni Shock Absorber - $152.74 2 $305.48
KCA412 Camber adj bolt kit-12mm - $71.82 1 $71.82
KCA338 Control arm-rear caster adj. - $143.65 1 $143.65
BMF14 Heavy duty swaybar-fr - $145.45 1 $145.45
BMR44 Heavy duty swaybar-rr - $145.45 1 $145.45
Subtotal: $1,514.05
Shipping to: Australia, NSW - via Courier: $28.00
Australian GST: $154.21
Total Order: AU$1,696.26
(Australian Dollars)
This is a quote I got from Whiteline. It's for a TR/TS because there is no kit for them yet.
Not a bad price I think...it's reasonable
Not to bad a price... Still then you have labour... you can get that cheaper, you don't have to go to whiteline. I know wilkingson suspension here in perth are dirt cheap and do a brilliant job.
If you are only changing springs, then you may need to use spring compressors which will funnily enough compress the spring! so you caqn out it in.
